Coolant fail, advice needed.
Barrow-in-Furness
Audi S3 2014
Hi all, just got myself a 2014 S3 and love it, however today it let me down. It has developed a coolant leak, while stopped at junction I noticed steam coming from engine bay, I pulled up and opened the bonnet, the steam appeared to be coming from the back of the engine, I took off the plastic cover and found the coolant bubbling (see attached video). I read all the threads on here regarding water pump failure but that would mean a leak from the bottom of the engine not where I’m seeing it. Has anyone else seen this?
Cycling_jonny
Barrow-in-Furness
Audi S3 2014
Update, I called the AA out to look at this issue, they are pretty confident it is a failed ‘o’ ring on the turbo water return pipe that has failed causing water to squirt out onto the turbo manifold. I now just need to find the correct part number and change it out. Photo below is the pipe with the failed ‘o’ ring where it attaches to the engine.
Cycling_jonny
Barrow-in-Furness
Audi S3 2014
Update…
Part ordered from Audi (part no. 06K-121-143)
The ‘o’ ring had failed, very easy fix, one torx screw and remove hose clamp. 👌
