ill be trying this out tomorrow.
this vcds coding is not new. i just happen to find it on other forums.
the coding is to help with the lag we get when just partial throttling the car or from slow starts from a red light stop.
from factory, the car's accelerator moves the throttle body by time and we are going to be changing it to a linear threshold in comparison to the accelerator pedal.
it should feel more smooth and less like your guessing when the car will move when you lightly press the pedal.
the second part might also help which is to align the throttle body. sometimes its off because of many possible reasons. so its good to realign it if possible. now i have not tried it yet and will post up links and you decide if it is what you need or not. the coding for this is directly from rosstech and i dont know the exact procedure till i try it out.
[Direct Acceleration - Throttle response]
With this mod, you can change the behavior of the accelerator. Option B provides a more linear acceleration without sudden deliveries.
1 - Module 44 - Power steering. Code (19249)
2 - Adaptation
3 - Select - switching driving profile
Choices :
A - Gradual, controlled by time
B - Directly controlled threshold value
throttle body alignment:
http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA)
2 - Adaptation
Choices :
