- Reactions
- 48
- socal.
- CA
- 2015 s3
so i have had this issue for a while but I never go around to fixing it.
at this point the weather is heading towards colder temps and I need to make sure I can defrost my front windshield. the issue has been where I would not got the normal full air at high fan speeds. so it wouldn't work as well as before.
if you are not aware, this unit allows the control of fresh air from outside the car to come into the car. if you close it off then the motor will move a flap to seal off air from coming into the cabin of the car.
so I used my obd11 tool and scanned. the b108b71 fresh air, recirculatio, air flap motor (jammed) code came up. its been like this for a while even when I cleared out the code a few times. so I know its something that is not a glitch.
after doing some research i found that for this particular model and year, there could be 2 different brands of motor.
brands;
1. johnson
2. sen
I'm not sure which one but from what i know we would want to match the same brand to what our current one is using.
using the vin will not tell you which one. what you'll need to do is to actually take it out and verify the part number on the motor unit.
when your dont installing, you will want to code it out to make sure that the motor has aligned properly with the flap. if you dont, it will not work right. if at all.
faq,
there have been updates to both models of motors.
motor 1: 5wa-907-511-c
motor 2: 2q0-907-511-f
ill know when i take it out but if you do it, take yours out and verify which one you'll need. there are just the possible new part numbers that are available at this time for my particular car.
here is a video someone did when they were installing a defrost motor, not exactly the same motor I'm doing.
View: https://www.youtube.com/watch?v=dplV5wKLUVo&ab_channel=PracticalEnthusiast
ill update when i do the job this week.
update:
* replaced the fresh air flap motor.
* used the more robust motor. 2Q0907511F
* used obd11 to calibrate a/c system, clear fault codes, and re-scan for any thing.
* 2nd, issue showed up. got a front defrost basic setting needed. tried clearing it and re-aligning it with obd11. keeps coming back.
* conclusion, its basically a damaged motor for that flap as well. different flap motor. in the diagram #7 motor.
the system seems to only have a few warning labels; stuck or basic setting set needed.
just state that the motor is not working anymore and needs replacing. it doesn't really mean that the flap is always stuck. the stuck part is saying the motor doesn't work and the flap is not going to move, hence the stuck part of the warning. so fix what ever is making the flap stuck/not moving. could be debris or the motor not working or even an electrical issue.
brands;
1. johnson
2. sen
faq,
update:
- Show All
