MAF sensor
St Austell
2011 S3
Hi, I have an issue with my 2011 S3 and would appreciate some support.
The MAF sensor keeps blowing.
This has had extensive investigation by an audi specialist who has not been able to determine the root cause.
For some reason the signal wire to the MAF sensor has a higher voltage than normal, <10V. I understand this should be less than 6V?
Does anyone have an overall schematic of the wiring loom that I can use to systematically work through? Are there any thoughts then on what the best approach is to work through the looms?
Any help, guidance would be very much appreciated.
Kind regards
Stu
