Audison APBX 10 AS2 Powered 10” Subwoofer + AudioControl LC2i Pro – Excellent Condition $525
Trader history for 404 (0)
Wilmington
DE
2025 Audi S3
Local pick up only - northern Delaware
Selling an Audison Prima APBX 10 AS2 10” powered subwoofer and AudioControl LC2i Pro line output converter that were professionally installed in an Audi.
Both components were fully functioning when removed. The car was traded and returned to the factory audio system, which is the only reason these are being sold.
The equipment is in excellent cosmetic condition and was well cared for.
Audison Prima APBX 10 AS2 Powered Subwoofer
10” subwoofer in factory Audison enclosure
Built-in 400-watt RMS amplifier
Protective metal grille
Original Audison SSP power connector included
Remaining power, ground and remote wire pigtails included as pictured
Original Audison bass-level remote/knob included
Important: the bass remote cable had to be cut during removal, so the remote cable will need to be replaced (if wanted)
Main vehicle installation wiring is not included
Currently sells new at Crutchfield for $799.99
2-channel active line output converter with AccuBASS
Excellent condition and fully functioning when removed
RCA cables included
Terminal block/connectors included but replacement wiring will be required for installation
Currently sells new at Crutchfield for $159
These can be purchased together or separately.
This was a great combination for adding a high-quality powered subwoofer to a factory premium audio system without replacing the factory head unit. Everything worked properly immediately before removal.
Total current new retail: approximately $959.
Please see photos for exactly what is included. Installation will require additional/replacement wiring and connectors as described above.
Selling the package for $525 ($475 for the subwoofer and $75 for the LC2i Pro separately).
